cutting fiberglass
Old 08-19-2003 | 04:06 PM
jafo272
Question cutting fiberglass
I'm replacing the small cup holders with jumbo's in my dash. What is the best way to trim out about 1/4" around the hole? I've bought a carbide cutting bit for my drimmel. any input would be great!!!
Old 08-19-2003 | 04:13 PM
glassdave's Avatar
Neno the mind boggler
yup, thats about the best way.if you wanted to use a hole saw you can bond a small piece of plywood over the back of the hole and use that to center the drill.
08 OPA High Points Champion
glassdave is offline
Old 08-19-2003 | 04:33 PM
Official OSO boat whore
I used one of those rotozip cutters in my dremel. Worked really well. I got maybe 6 rectangular switches out of the bit before it burned up.
You could also try fitting two hole saws inside of each other.
Cord is offline
Old 08-19-2003 | 04:41 PM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
Place a STRONG vacuum (hose) under the area you are cutting, and turn it on when cutting. It will aide you in clean-up. Rotozip tool works very well for this.
Sydwayz is offline
Old 08-19-2003 | 06:06 PM
Madcow's Avatar
Just go slow and easy. I did 3 in my boat 2 weeks ago with a dremel. It wants to wander on you if you push to fast.
Madcow is offline
Old 08-19-2003 | 07:10 PM
Raypanic's Avatar
I used a coarse sandpaper flap wheel about 1 1/2" in dia. I put it in a die grinder and it cut the glass very nicely. Definitely use a vacuum. Just use a marker to scribe a line and sand to it.
Ray
Raypanic is offline
Old 08-19-2003 | 10:32 PM
Andy Buzz's Avatar
I always put masking tape over the area to be cut and draw cut line with a contractors pencil. Bear in mind that the melted fiberglass from the rotozip will be hot and can melt vinyl so protect things around the cut.
Andy Buzz is offline
Wahoo ATV
OPA/The Jersey Boyz
33
05-21-2008 04:35 PM
nocigarette
19
09-12-2006 09:05 PM
Dave M
5
04-08-2003 09:39 PM
rtn137
21
03-16-2003 07:13 PM
NotTOOBAD
Baja
4
02-16-2003 03:42 PM
