Hit stick or bark, speedo stopped working??? >
Old 08-23-2003 | 03:07 PM
East Coast B's Avatar
Default Hit stick or bark, speedo stopped working???
I must have hit a stick or wooden object... I found the inlet on the outdirve for the speedo on my bravo3 filled with wood. My speedo is stuck on 20mph while on the trailer. I tried to pull out as much off the wood as possible, but the speedo is still on 20mph... How do I correct this problem??
East Coast B is offline
Old 08-23-2003 | 05:07 PM
CAP071's Avatar
blow the line out with air from the other end
CAP071 is offline
Old 08-23-2003 | 05:52 PM
Madcow's Avatar
Buy a GPS Speedo. That will fix the problem.
Madcow is offline
Old 08-23-2003 | 06:28 PM
Audiofn's Avatar
Charter Member #232
Try and use a small piece of wire to snake up there. You can also some times use a drill bit to free it up.
Jon
Put your best foot forward!
Audiofn is offline
Old 08-23-2003 | 06:32 PM
I'm assuming that once I get it free, the speedo will drop to zero? Is there pressure in the line that is holding the speedo at 20mph?
Thanks for your thoughts guys!!!
Old 08-23-2003 | 08:45 PM
Allan4
MIne has not worked since I bought the boat 4 years ago. I finally just bought a GPS. Boat was 1 year old when I bought it....
Good luck...crappy design....
Old 08-23-2003 | 11:53 PM
Mark D's Avatar
Yes, there is water pressure in the line. You still have debris in there. You can use a thin drillbit if careful.
I had that happen to my current boat many times & as soon as I freed the line the water sprayed out & the speedo went back to zero.
I agree GPS is the only way to go..
Mark D is offline
Old 08-24-2003 | 06:29 AM
Payton's Avatar
Charter Member #927
yep, what they said. Drill bit and GPS
Payton is offline
Old 08-24-2003 | 06:55 AM
After I got the wood out that was visible, I took a paper clip and unfolded it and started probing the water inlet. Kept turning it around and around sort of drilling into it, I could see little bits of wood coming out... finally some water and walah!!! Some water came out and the speedo dropped...... ... My boat isn't top end boat, I mainly view the speedo as a guage to tell me if it's running correctly or not...... so a gps isn't really warrented.. maybe next boat!!!! Thanks for everyone's comments!!!
Old 08-24-2003 | 12:03 PM
mcollinstn's Avatar
glue a drill bit in a piece of wood dowel. Can jump in and use it while you are anchored if necessary. If you drop it, it will float to the top.
mcollinstn is offline
CObarry
04-23-2005 09:21 PM
aTX427
4
08-05-2004 10:52 AM
Raven
4
07-16-2003 05:43 AM
97BossHammer
11
04-18-2002 05:39 PM
