Best place to buy stainless hydraulic (trim) hoses?
I need the hoses that run from the my pump to the hydraulic "JUNCTION BOX" on the bottom of the drive gimbal 6ft. I cant find any place in my area that has stainless fittings and every marine place that I called doesnt have 6 ft. listed as a merc part number. Any suggestions on where to get some made that have stainless fittings?
Official OSO boat whore
I used hydraulic brake line for my boat. You just can't get the ends in stainless. I ended up with a steel fitting with a special silver coating.
I've got a set that I just removed from my boat when I replaced the transom assy. It came with new hoses. They are 1994 Bravo hoses and are in great shape. Give me a call at 847-902-9702 after 9:30 pm central if your interested. Maybe we can swap or something ???
Dave
Dave
If you go to your local hydraulic supply store you can buy the hose and reusable s/s fitting, Parker is one brand we use they are in Ravenna Ohio, we use a 20690-4-4c SAE 37degree swivel, you will also need an adaptor from inverted flare to -4 JIC this fitting can be brass and found in the Weatherhead fittings at your local autoparts store.
There is a hydraulic supply shop in Westerville that has the parts and can make hoses.
THRILLSEEKER
07-11-2002 12:19 AM
