gimble bearing alinement >
Old 09-06-2003 | 11:17 PM
ragtop409's Avatar
Question gimble bearing alinement
How do I know if it is on, or how close does it need to be? I have the tool and it slides in and out. Just not sure if it is to tight. I had imagined it like a guy and girl guess it might be. Serously when do I no I have it adjusted right, or good enophe. All help or coment apreciated. Rag's
ragtop409 is offline
Old 09-06-2003 | 11:21 PM
Dennis Moore
Sounds like your OK. At Mercruiser service school they say it should slid in and out with a couple of fingers around the shaft. Are we still talking about boats?
Dennis Moore
Old 09-06-2003 | 11:24 PM
Tinkerer's Avatar
The tool has to bottom out easily and You should be able to remove the tool with very slight pulling.
Tinkerer is offline
Old 09-07-2003 | 09:17 AM
Audiofn's Avatar
Charter Member #232
I am in headed to the bedroom to check for proper drive allignment.... I will let you all know how it goes
Put your best foot forward!
Audiofn is offline
Old 09-07-2003 | 09:27 AM
Al Oakley
put some grease on the end of the tool and insert tool,look at the imprint of the splins in the grease. should be evan all the way around.and slid in and out with out binding.pull strieght out to get a good imprint
Old 09-07-2003 | 09:58 AM
formula31's Avatar
The roll then engine 180 degrees and check it again to be sure the coupler is centered on the flywheel, some are not.
formula31 is offline
Old 09-08-2003 | 09:30 AM
Raypanic's Avatar
I found when they are right when the tool is pushed in rather fast will bounce back a little, if too tite it will have no rebound
Ray
Raypanic is offline
awesomecat26
Drives and Lower Units
3
08-13-2007 11:28 AM
rush
10
07-28-2006 07:30 PM
Elite Marine
1
07-12-2004 06:33 AM
Raven
2
06-02-2003 08:17 PM
Raypanic
11
05-01-2002 01:23 AM
