Big Block Vortec heads airflow data...?
Those aren't correct, those #'s indicate they flow worse than stock peanut ports. I'm betting those are the #'s for SMALL block vortec heads.... those would be much more like what a decent small block head would flow.
Madmax is right, the numbers are likely for small block heads.
The link is good sutphen30, lots of good info, no L-29 heads though.
Donman, you may want to try numbers in between the GM 049 and the WP Merlins.
Are you running numbers for the ZZ502 cam ???
I need to buy that desktop dyno...
Patrick
Patrick
Originally posted by Pat McPherson
Hey DonMan,
Are you going to put bigger valves in those heads?
Post some numbers if you don't mind.
Hey DonMan,
My 454 went kablooey so I`m considering building a 496 shortblock, possibly a 540....
I know these heads aren`t that great, but I already have them and really can`t afford better heads right now. Just hoping to get a little good from them.
So, OK give me flow numbers for 049 and Merlins.
Hey DonMan,
Sorry to hear you 454 went boom
sutphen30 posted a link to the flow numbers from high performance chevy.
Would you mind running the numbers for the ZZ502 cam in a 454?
Patrick
Patrick
