brand new jet engine on ebay! >
Old 09-11-2003 | 01:40 PM
puder's Avatar
speel chekk this fokker!
Default brand new jet engine on ebay!
http://cgi.ebay.com/ebaymotors/ws/eB...category=26428
seems pretty cheap to me!
Pardon me, while I whip this out!
puder is offline
Old 09-11-2003 | 02:10 PM
Looks like a little Allison. Unfortunately, they're only about 300hp.
Gary
Gary Anderson is offline
Old 09-11-2003 | 03:23 PM
Fountain38SC's Avatar
The seller is probably right, exmilitary. No books, no power, no value.
Fountain38SC is offline
Old 09-11-2003 | 03:53 PM
T63-A-700
The Allison T63 is a free-shaft axial/radial flow gas turbine. The compressor has 8 stages, 7 axial and 1 centrifugal. The compression ratio is 6.2:1, it flows approximately 3.0 lb/s (2,250 cfm) @ 51,600 rpm. The combustion chamber is a single can design. Two turbines drive the compressor and two drive the load through the gearbox (front or rear) at 35,000 rpm. Specific fuel consumption is 0.7 lb/shp/h. The engine weighs 138 lb and produces approximately 317 hp. (2.33 shp/lb) With the integral reduction gearbox this engine will produce 277 lb-ft of torque at 6,000 rpm.
$15K seems kind of expensive for the performance of a 350.
Gary
Old 09-11-2003 | 04:14 PM
puder's Avatar
my B.
i though that it was one of the ones they use in unlimited hydros. I guess those are from bigger choppers not hueys.
although in a small single engine boat tha might be cool. save 700lbs over a big block and make about the same HP.
puder is offline
Old 09-11-2003 | 06:55 PM
tachyon's Avatar
Puder,
The unlimited use Lycoming T55-7C turbines. They are out of Chinooks and make approx. 2500 hp in todays fuel restricted hydro racing. They cost about 120k for a tight engine thats been marinized. They can be had mush cheaper but you'll pay in the long run...
tachyon is offline
ak
14
01-19-2008 06:34 PM
fobes
Sutphen
3
05-09-2006 08:01 PM
105mph_38_2003
07-18-2005 07:34 AM
CAP071
02-23-2004 05:39 AM
VelocityMike
11-26-2002 08:20 PM
