Polyester gelcoat on epoxy >
Old 09-15-2003 | 01:00 AM
Bulldog's Avatar
Default Polyester gelcoat on epoxy
Fiberglass experts-
My hull is epoxy/kevlar and I read that there is an adhesion problem with polyester on epoxy resin. Is this true with polyester gelcoat on epoxy???? I pressure washed the fuel tank bays and was able to dislodge about 25 percent of the gelcoat with ease.
Also, what brand/type is the best gelcoat to use? The hull is white with a layer of black underneath.
Ronnie aka Bulldog
Bulldog is offline
Old 09-15-2003 | 10:33 AM
CALL MICHAEL AT SEEMAN FIBERGLASS IN HARAHAN
504-738-6035 HE CAN PUT YOU IN THE RIGHT DIRECTION. ERIC....
open87 is offline
Old 09-15-2003 | 10:52 AM
GregP's Avatar
One way works, the other doesn't. I "think" it is epoxy will stick to poly but poly won't stick to epoxy.
-Greg
GregP is offline
BraceYourself
05-21-2008 06:53 PM
BraceYourself
Outerlimits
0
05-21-2008 12:44 PM
jdub
Detailing, Painting, & Fiberglass
4
01-27-2006 09:20 PM
blue thunder
4
04-04-2004 05:22 PM
