C4 Corvette Problems
Old 09-18-2003 | 10:43 AM
HyperBaja's Avatar
Default C4 Corvette Problems
No, I didnt break it, dad has.
First Problem- When starting after it has set for more than a few hours, it takes a while to finally start. Turns over fine, just wont kick over on its own. When it does, it smells REALLY RICH. Fuel injector problem?
Second Problem-Brakes...Brake light is on like when you have the hand brake on. petal is VERY light, and dosent like to stop much. Brake master solenoid?
Edit-It is a 1988 TPI Corvette with 51k miles.
HyperBaja is offline
Old 09-18-2003 | 10:47 AM
SS930's Avatar
1-Leaking injector, cold start injector
2-Check the fluid level, bad master cylinder, old fluid, leak in system
Just some VERY QUICK thoughts
SS930 is offline
Old 09-18-2003 | 10:48 AM
Indy's Avatar
Member #154
Post over at www.corvetteforum.com There's a C4 section that will help you.
Indy is offline
Old 09-18-2003 | 11:15 AM
lottawatta
HyperBaja,
Hold the accelerator down to the floor when cranking, if I start right up, it is the injectors leaking down. Had the same problem on my C4. Injectors fixed it.
Brakes: no idea.
Corvetteforum.com Rules!
Old 09-18-2003 | 11:51 AM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
The brake light being on; half lit, might be an indicator of an ABS problem. Same problem on my 1989 S-10 Blazer. See if you can find a verticle mounted ABS controller next to the master cylinder, and unplug the connector off of the back of it. It is a long connector, and the box is about the size of two slices of bread next to each other ( ll ). If the light goes out, you have found your problem.
Sydwayz is offline
Old 09-18-2003 | 11:54 AM
TEAMBAJA's Avatar
Originally posted by lottawatta
HyperBaja,
Brakes: no idea.
After the 95 speeding ticket in the Ranger, I dont think HyperBaja should even sit in a Corvette!
TEAMBAJA is offline
Old 09-18-2003 | 12:07 PM
Yes, I Thought He Had Trouble Keeping Rubber On The Rear Tires!!!!!!!!!!!!!!!
neu-rich is offline
Old 09-18-2003 | 02:08 PM
HyperBaja's Avatar
No, I havent done a lot of burn outs in that car, but the 0-45 is faster than I have time to take the foot off the gas haha, gotcha.
HyperBaja
12-18-2003 10:10 PM
Back4More
11-22-2003 03:32 PM
