Truck Brakes gone!!! >
Old 09-19-2003 | 07:20 AM
dyno's Avatar
Charter Member #655
Default Truck Brakes gone!!!
I know its off the subject but the wife just called and lost her brakes on the way to work. I could hear a hiss inside the truck last night when the brakes are applied. Called Crazyhorse my machanic buddy and he thinks the vaccum booster is shot. How big of a deal is it to fix ??? worth doing or should I call a wrecker to go get the wifes truck and have it fixed???
Help!
dyno is offline
Old 09-19-2003 | 07:33 AM
birdog's Avatar
Not to bad a fix......Call around there are places that rebuild boosters pretty cheap.....
birdog is offline
Old 09-19-2003 | 08:00 AM
28Eliminator's Avatar
Dyno, not knowing what your truck is, changing the booster usually isn't to bad at all. You may not want to change it where it's at, depending on where your wife left the truck. I would probably just change it myself, but be prepaired, if you have to disconnect the break lines, then you will need to bleed the brakes. Not to say that you will have to, you just have to look at it. If you can swing the master cylinder out of the way, just pull the booster, change it, and bolt it back together.
28Eliminator is offline
Old 09-19-2003 | 09:12 AM
dyno's Avatar
Charter Member #655
Thanks Guys I have a booster on hold at Auto Zone for $116, 28Eliminator the Truck is a 1999 Tahoe shouldn't go too bad. Crazyhorse said I could change it at his house its only a couple miles from my wifes office hope I can get stopped when I get there!!!maybe I should just grab the anchor out of the boat and give it a toss out the window when I get in his driveway!!!
If your boat has a sail do you ride a horse to the ramp?
dyno is offline
Old 09-19-2003 | 11:20 AM
Crazyhorse's Avatar
her brakes are still there. they're just sleeping.
Crazyhorse is offline
Old 09-19-2003 | 11:33 AM
dyno's Avatar
Charter Member #655
very very sleepy!
dyno is offline
Old 09-19-2003 | 11:43 AM
Crazyhorse's Avatar
just thinbk how good they'll be when they wake up.
THEJOKER
33
12-19-2007 09:09 AM
Chris Sunkin
32
04-04-2007 05:41 PM
cbeastwood
4
01-01-2007 08:27 PM
PWRCAT
16
06-01-2005 05:47 PM
srpbaer
3
06-03-2003 08:17 AM
