Can you put bushings in Dominator throttle shafts? >
Old 09-20-2003 | 08:59 PM
Default Can you put bushings in loose Dominator throttle shafts?
My shafts are worn and before I replace the entire carb, can I machine it for bushings or can I just replace the throttle base plate?
jody165 is offline
Old 09-21-2003 | 03:36 AM
RLW
Call Dean or Brad Nickerson at: 215-781-1370
www.nickersonperformance.com
RLW is offline
Old 09-21-2003 | 07:15 AM
Official OSO boat whore
I believe that a rebuild shop can. The problem is that they need to be perfectly aligned or the shaft will bind. They usually use a jig for this job.
Cord is offline
Airpacker
08-06-2008 08:53 PM
Josh Carr
11
05-05-2008 06:56 AM
team Tickfaw
5
02-29-2008 08:06 PM
riski bidness
2
08-10-2006 10:02 AM
RLW
4
02-18-2003 10:15 AM
