Prop for hole shot >
Prop for hole shot
Prop for hole shot
Old 09-23-2003 | 08:47 PM
Default Prop for hole shot
My current 19p will spin 5200+. Will a 19p 21p or 23p give you the best hole shot. I do understand proping and rpm on the high end. What pitch will give you the most bite comming out of the hole. Is more pitch better?
thanks
FlyFast is offline
Old 09-23-2003 | 08:54 PM
mopower's Avatar
Toxic FORMULA
FF,
No, the 19 will do the most for your hole shot .
Also four blades usually help coming out of the water too
mopower is offline
Old 09-23-2003 | 10:30 PM
Al Oakley
remember the more out of the hole the more top end you lose .the merc. high five gives the best hole shot that i have found yet .what drive do you have ?
Old 09-23-2003 | 10:54 PM
Thanks,
I have a vortec 355 with an airgap intake, 4 barrel turning an alpha I gen 2 and it jumps up on plane. I know I can turn a bigger prop on the high end but I love the hole shot for water skiing. On my high end I can only get 50 from the boat when it is light. With a 21p I could probally add 2 knots and turn 5k or a 23p add 4 knots and turn 4800.
Most of the time we do watersports and maybe the 19p that gives me the best hole shot is also the easiest on the motor. Maybe I won't stretch my rods again with the 19p. No knocks is a good thing.
FlyFast is offline
TeamSaris
Classic Offshore
10
07-29-2008 09:55 PM
Jolley
05-14-2003 09:47 PM
SHARKEY-IMAGES
03-25-2003 05:28 PM
