Trailer question >
Trailer question
Trailer question
Old 01-10-2002 | 06:00 PM
BryanTuvell's Avatar
Donzi33ZX
Post Trailer question
I have a new fastload 2628, the alum frame is 6.5 inches tall, I am looking for a spare tire mount to us on the Y of the frame that lifts the tire up so I do not loose clearance.
Our local tire store and West marine only have the ones that work on the 4 inch trailer beam height.
I could lay it flat and U bolt but that is not my preference since the rim matches etc... we travel/tow allot so I hate to use room in the grand cherokee.
Open to links and ideas....
Thanks in advance as always.
Bryan
BryanTuvell is offline
Old 01-11-2002 | 07:27 PM
Post
Some of the carriers designed to u-bolt to 4 inch frames will also work on the taller frames by drilling holes thru the frame members to mount the carrier. Get a can of spray galvanize to re spray after drilling the holes and you should be good to go.
bucky is offline
Old 01-11-2002 | 07:34 PM
Waterfoul's Avatar
Gone Fishin'
Post
My bet is you could probably make one from "stuff" found at your local reputable hardware store or home depot. I'll just bet that you are smart enough and good enough with tools to make something work for you that looks good and works well.
Have you considered mounting it horizontally just behind your bow support?
Waterfoul is offline
Old 01-11-2002 | 07:36 PM
traviss's Avatar
Post
how about just throwing it in the truck... The trailer looks alot nicer without
traviss is offline
Old 01-11-2002 | 10:06 PM
thespy's Avatar
Post
Try going to a welding shop and have them build you 12-16" bracket that can be bolted to the frame at the front of the trailer, the real cool ones would have a axle spindle and hub, thus giving you plenty of extra parts, when needed.
Parts:
1 bottom mounting plate 4 " X 6"
1 12-16", 2 1/2" square tubing or round
1 spinde
1 Hub, and nuts
Hey stop on over, we can build it tonight !!
thespy is offline
Old 01-12-2002 | 01:07 PM
Ron P's Avatar
Enjoy the show
Post
Call Myco trailers and get one of their spare tire brackets and bolt or weld it on.
Ron P is offline
Old 01-13-2002 | 05:28 PM
Scott B's Avatar
Cool
Bryan,
Long Run marine products makes a bracket with a 5 lug hub already mounted to it. Wholesales around 45 / 48 bucks as I recall. If you have a 6 lug hub, you will end up fabbing one. It is nice having a complete spare hub and bearings..
Scott B is offline
Fast Forward
Powerquest
11
03-07-2008 08:41 PM
CigBoat
11-03-2004 03:51 PM
chriscraft240
18
09-16-2004 01:18 PM
Tantrum
03-14-2003 11:33 AM
NVRENOUGH
04-26-2002 09:07 PM
