Diff. between RH and LH drives? >
Old 01-10-2002 | 07:50 PM
mleslie951's Avatar
Post Diff. between RH and LH drives?
I recently purchased a 28 Apache Brave (twin bravo 1's 1:36 gears, 502 carb's). My question which may sound stupid, how can you tell if the Bravo's are RH/LH drives? Is it which way the props turn clockwise/counter clockwise? Stepped up to a twin and looking for speed? Currently running 23' Mirages.
mleslie951 is offline
Old 01-11-2002 | 12:19 AM
Audiofn's Avatar
Charter Member #232
Post
The Bravos, and only the bravos are the same. TRS and Alpha drives are different. They are stamped on the end of the drive shaft LH of RH to tell you what they are. To make a Bravos go the other way you just swap the shifter and they will change dirrection.
Jon
Put your best foot forward!
Audiofn is offline
Old 01-11-2002 | 08:25 AM
CelticPride
Post
----yea, what he said...but don't forget to switch the props also..
Old 01-11-2002 | 11:17 AM
mleslie951's Avatar
Post
Audiofn/Celtic Banshee thanks for the reply. This will be beneficial when I jump to larger pitch props.
Old 01-12-2002 | 10:00 AM
jbrauer's Avatar
Post
Apache, I had the same question and got some great answers to my post in the "Testing and Upgrades" section.
jbrauer is offline
Tony Montana
Powerplay
5
06-05-2006 08:54 PM
Pure Energy
12-05-2005 10:41 AM
Jassman
26
01-04-2005 06:05 PM
activox
10-14-2004 08:48 AM
WES311SR1
04-27-2002 08:39 AM
