Can I spray soapy water on my 502 ? >
Old 10-08-2003 | 12:32 PM
Question Can I spray soapy water on my 502 ?
I've got 2 oil leaks on my 502 and was thinking about putting some air pressure on the crankcase when the motor is out and spraying soapy water on the suspect areas looking for bubbles. Anyone do this before? will it work? greg
HPJunkie is offline
Old 10-08-2003 | 12:41 PM
Lee's Avatar
Lee
Try this stuff works great. Just add to engine oil and use a blacklight
Lee is offline
Old 10-09-2003 | 04:32 AM
Mbam's Avatar
Offshoreonly Advertiser
Greg, yes we do it all the time. The crankcase really won't hold a lot of pressure, as the rings will pass air out the cylinders. We use a pressure regulator and just a couple of PSI. The black light dye is also helpfull as Lee says.
Mbam is offline
Old 10-10-2003 | 06:25 PM
martiniboat's Avatar
From: Brussels, Ont. CAN. Landlocked between Lake Huron, Ontario and Erie
Here's my 02 cents.
I've never ever come to grips with Mercurys' decision to paint their engines black. It's hard enough to find a small leak from the getgo (I know you're removing your powerplant) without complicating the process with a paint 'colour' that's the same as oil. Every engine I do is a lighter colour when I'm finished. This was the latest. 502 with Merlins and all the goodies.
Later, Brian
martiniboat is offline
nwcrob
11
01-05-2009 01:44 PM
C_Spray
03-28-2008 07:31 AM
dennis rider
6
06-11-2003 06:53 AM
doright
1
04-23-2003 07:25 PM
