Diet for the boat
Old 10-09-2003 | 10:31 AM
Default Diet for the boat
Looking for ways to reduce the weight of the cat.
Some ideas:
Currently using 2 of the large/racing Stainless Marine sea strainers. How about removing one strainer, have both water pickups feed the remaining strainer and have both engines feed off of it. The strainer already has the fittings. See photo.
I seldom use drive trim (except for removing props) or seldom move the tabs (independently):how about using one pump to trim both drives and one pump to adjust both tabs. They would adjust as pairs.
I think the Zynetix/Fountain Super V used these ideas.
What're your opinions?
John
Dueclaws is offline
Old 10-09-2003 | 12:36 PM
ChrisK's Avatar
Moderator
I dont see how taking these few things out will make that much difference in weight. You are talking about maybe 75 lbs? if that.... In a boat that weight how many thousands of pounds, it is a minute amount of weight.
ChrisK is offline
Old 10-09-2003 | 12:59 PM
Chris- You're correct, but 75 here and 75 there: before you know it you can have a significant amount of weight removed.
John
Dueclaws is offline
Old 10-09-2003 | 02:50 PM
mcollinstn's Avatar
Can't run a single trim pump to both sides. You can, however, downgrade to a little teeny pump that may save a few pounds and take three times as long to trim.
With a single pump, there is still push down on one drive and the other will go up...
mcollinstn is offline
Old 10-09-2003 | 03:15 PM
Airpacker's Avatar
Invite one less passenger along and you have your 75 plus already gone,no muss,no fuss
Airpacker is offline
Old 10-09-2003 | 03:22 PM
rws's Avatar
rws
To lighten the Hoods on Drag Race Snowmobiles we used to get out The Grinder!!!!
Rob
rws is offline
Old 10-09-2003 | 03:28 PM
rws-
Funny that you should mention that!! I've considered it. But this thing is 40' long!
Hmmm, maybe I can hire some cheap help.
Just kidding
John
Dueclaws is offline
Ms PatriYacht
01-10-2004 11:31 AM
