bore size?
Old 10-15-2003 | 05:58 AM
dyno's Avatar
Charter Member #655
Default bore size?
whats the largest I can bore a Gen 5 454? can I sleeve it and go really big???I'm .030 over now whats a safe bet? Dont want to weaken the block too much......
dyno is offline
Old 10-15-2003 | 10:24 AM
dyno's Avatar
Charter Member #655
tt
If your boat has a sail do you ride a horse to the ramp?
dyno is offline
Old 10-15-2003 | 01:25 PM
.060 over is a 468ci. and is pretty common. I have heard that you should have some kind of test done to the block to make sure you can go .060 over due to wall thickness.
Griff is offline
Old 10-15-2003 | 01:30 PM
I don't know about gen 5, but I am .070" over on my 498" Mark IV and I have heard of guys going .100" over on blocks with minimal core shift.
WETTE VETTE is offline
Old 10-15-2003 | 02:05 PM
dyno's Avatar
Charter Member #655
I just was wondering what size cubic inch I could manage without trashing the block I'm planning on building some 4.25" stroke motors next time around......060 over with the 4.25" crank is a 496 right?
dyno is offline
Old 10-15-2003 | 04:36 PM
PatriYacht's Avatar
Before the 502 came out, a lot of guys were building 496's. If you need to in the future you should be able to bore it once more. .080 or even .100 is possible on some blocks. Just have it sonic checked. I had a 427 in a 68 Vette bored .100 with a solid lifters. Revved it 6500 on many occasions.
PatriYacht is offline
Old 10-15-2003 | 06:58 PM
Crazyhorse's Avatar
Hee's what you do Dyno. Punch the first one out until you hit water and sleeve it. Then just don't bore the others as far,,,,,,,,,,,,,,,,yeah, I thought you'd like that,,,,,,,,
Crazyhorse is offline
Old 10-15-2003 | 08:30 PM
formula31's Avatar
I know quite a few bowtie blocks that have gone as far as 4.5 which is .250 over. Personally, I wouldnt go over .060 without filling at least some of the water jacket to give it strength
formula31 is offline
Old 10-16-2003 | 05:37 AM
Dyno....save your money from boring......stay low compression.....030 - .060 over and BLOWERS!....I think Crazyhorse will agree!......Fred
fred is offline
Old 10-16-2003 | 06:03 AM
dyno's Avatar
Charter Member #655
Been there done that!!!was broke alot!!!
dyno is offline
Vyper340
10-10-2006 09:15 PM
gg10
2
11-20-2005 06:14 PM
MILD THUNDER
2
07-25-2005 10:13 PM
timucin
1
03-19-2005 07:39 AM
formulaF302
15
06-16-2003 11:49 PM
