pushrods bb-chevy
When you start playing games with cams, lifters, heads, and deck heights you must install the test adjustable pushrod and follow the directions supplied therewith to determine the length of pushrods that you must then order.
When you start playing games with cams, lifters, heads, and deck heights you must install the test adjustable pushrod and follow the directions supplied therewith to determine the length of pushrods that you must then order. YES, SIZE DOES MATTER!! More than .050 off in length and your rocker will not be pushing and rolling or sliding over the center of the valve stem. And that ain't good! --- Jer
