Go Back  Offshoreonly.com > Owners Forum > Excalibur
3 blade vs 4 blade on 40' Hawk >
Old 11-03-2003 | 01:04 PM
Default 3 blade vs 4 blade on 40' Hawk
I have a 40' Excalibur Hawk and was wondering if anyone has moved from 3 blade Mirages to 4 blade Bravo or Hydromotive props, if so what were or are the advantages and disadvantages you experienced, I have been told that the 4 blades give more stern lift and a higher cruise speed at a lower rpm....please inform me, Thanks, Fred
fred is offline
Old 11-17-2003 | 06:11 AM
Gottime
I have a 40 also i ran 4 blade but i also put a set of 250 megablowers on it the boat did have more stern lift ran faster at lower rpm plus it made it get up and go better off the start..
Old 11-17-2003 | 06:53 AM
dyno's Avatar
Charter Member #655
Fred two words...... MORE POWER!!
If your boat has a sail do you ride a horse to the ramp?
dyno is offline
Old 11-18-2003 | 02:21 PM
Dyno, your right...won't happen soon as I will have my second daughter in college soon.....still doin what I can to squeeze out any available ponies....hope the props coming back from Houston (Darin) help a lil bit....Fred
fred is offline
Old 11-18-2003 | 02:24 PM
Gottime, how much did the 250's help you?....what size motors are you running with what mods on them?...Thanks Fred.
fred is offline
Old 11-26-2003 | 02:24 PM
Gottime
Fred the only thing i did to my motors was fresh set of pistons bored the motors 30 over put a set of full roller cams and lifters the motors were set of stock 454's the megablowers woke them right up ran 7 1/2 lbs of boost all summer long boat ran great between the motors and props i saw an increase of 10 MPh on the boat. ran lower RPM for cruising speed also
Old 11-29-2003 | 05:21 PM
dyno's Avatar
Charter Member #655
I thought the Megablowers were the big ones not the 250's....
dyno is offline
fandango
Wanted
6
05-15-2008 07:14 PM
Inspector
Prop Talk
1
07-09-2007 07:50 AM
bonecrusher
03-09-2007 09:12 AM
wtpowered
Prop Talk
7
07-04-2005 02:34 AM
Intolerant1
04-08-2002 08:08 AM
