Darin/Houston Prop - What's this? >
Old 11-14-2003 | 03:21 PM
CigDaze's Avatar
Default Darin/Houston Prop - What's this?
Originally posted by HOUSTONPROP
...the new acclerator blade design...
In another thread you were talking about Mirage Plus props and you mentioned the above. Had the prop been redesigned? How's it better?
CigDaze is offline
Old 11-16-2003 | 06:06 AM
HOUSTONPROP's Avatar
Default ACCLERATOR PROP
Its a stock, Mirage plus prop that after labbing the prop and making custom or hidden changes to the prop ,it works better than ever.
And will set you back in the seat with improvments of best of both worlds.
quicker to plane
acclerates hard and fast
mph gains of 2 to 3
you can have weld in hub inserts for extreme high hp
stainless drop inserts, avaliable per request
its sharp and shiney and Fast
it's smooth
it does not blow out
and you can trim to very high angles for reduced drag
WE CAN BUILD ONE OR MODIFY YOUR PROP/
prop is redesigned by Houston Propeller.
AND I CALL IT " THE ACCLERATOR PROP....
HOUSTONPROP is offline
Old 11-16-2003 | 06:50 AM
also to add ,I have taken some raw castings,worked it to the Mirage Plus pitch block,made my trade secret changes and wham-o - you have it.
THE ACCLERATOR PROP BY HOUSTON PROPELLER.
Darin
Old 11-17-2003 | 08:05 AM
CigDaze's Avatar
Wow, Darin! That's great to know. That's a cool name for it. Thanks.
CigDaze is offline
Old 11-17-2003 | 11:56 PM
IRONMAN's Avatar
How would it compare to a labbed bravo 1 at approx. 80mph on a 4400lb deep V?
IRONMAN is offline
Old 11-18-2003 | 12:28 AM
Talking ACCLERATOR
The ride is going to be alot more unstable at speeds over 80 ,that's where the four blade come in really nice is for the handling,
sure it would run faster but it would be HOLD ON
WHAT pitch B-1 are you running?
Darin
Old 11-18-2003 | 12:32 PM
IRONMAN's Avatar
26" . How much midrange speed would I loose at a given rpm? How would it compare to a Hydromotive 3 blade? Thanks, Chris
IRONMAN is offline
Old 11-18-2003 | 12:58 PM
Post ACCLERATOR PROP
Chris the hydro is a stern lifting prop,where this prop is a bow lifting prop big difference.
27 ACCLERATOR PROP would be quicker out of the hole and midrange would be alot quicker and as far as top end just depends on how far you go.
Darin
Old 11-18-2003 | 09:53 PM
sorry,the Bravo is just fine as is ,but we can make all kinds of changes that may help your situation,give me call,Darin 281-580-7767
HyperBaja
06-30-2004 01:50 AM
racinbird
Baja
7
02-25-2004 10:10 AM
JimV
1
01-14-2004 06:01 AM
wwwTOPDJcom
10
08-04-2003 08:52 AM
Luv-N-It
Baja
3
10-21-2002 02:36 PM
