Cold weather fiber-glassing ? >
Old 11-21-2003 | 08:16 PM
VintageOffshoreClassic's Avatar
Default Cold weather fiber-glassing ?
My question is how cold can the air temperature before you have curing problems ? above 48 ?
Answer is ?
Thank you Hugh
VintageOffshoreClassic is offline
Old 11-21-2003 | 09:37 PM
MitchStellin's Avatar
The colder it is the longer it will take to set up. I was told 60 deg was a minimum. I think the main problem is the set time when cold.
MitchStellin is offline
Old 11-22-2003 | 07:45 AM
45sonic's Avatar
That redefines the term "cold molded"
I have worked with glass in cold temperatures and it just doesn't work. While it takes longer to set up as it produces heat to set it does not adhere very well. Best to have temps above 60-65 or be able to heat the repair area for a period of time prior to repair
45sonic is offline
Old 11-22-2003 | 09:29 AM
CustomRigger101's Avatar
thunder might be able to spend some light on this.. but i think you can get one of those really hot lights and point it right at the spot that you want to repair..
CustomRigger101 is offline
Old 11-22-2003 | 08:18 PM
Audiofn's Avatar
Charter Member #232
Yup keep the resin inside and then heat the area up with a shop light or those hallogen job site lights. Not to hot. Just enough to get it up to say 70 degrees. You want the heat to be the entire area not just getting the surface hot. Then once the area is repaired make sure you keep the light on it to keep it warm and you should be fine
Jon
Put your best foot forward!
Audiofn is offline
Old 11-22-2003 | 08:30 PM
HyperBaja's Avatar
Jon
Ive done that...And to save energy, kept the garage door closed. When you stand up you really notice it.
HyperBaja is offline
Old 11-22-2003 | 09:44 PM
Thanks guys,
The boat a little large for the garage and the repair is quite large it's the whole deck being re-constructed.
VOF
fountain 47 sc
Fountain
6
10-02-2008 07:13 PM
Budman
10-03-2003 12:26 PM
mopower
01-26-2003 09:11 AM
Jayl13
12-18-2002 02:24 PM
CigDaze
02-28-2002 02:52 PM
