thunder bolt dist. >
thunder bolt dist.
thunder bolt dist.
Old 01-17-2002 | 10:39 AM
dyno's Avatar
Charter Member #655
Post thunder bolt dist.
anybody got a couple they want to sell????putting SuperV's motors back together and the distributers seem real sloppy can they be rebuilt? and if so what does it cost? I think its time for MSD's but checking all possibilities thanks
Don
If your boat has a sail do you ride a horse to the ramp?
dyno is offline
Old 01-17-2002 | 12:24 PM
formula31's Avatar
Post
I bushed and o-ringed my stock merc distributors and they worked fine. If you do it, remember to drill a tiny hole down from the oil journal to oil the gear.
formula31 is offline
Old 01-17-2002 | 05:57 PM
blue thunder's Avatar
Post
Formula 31... I know of the bushings you refer to... but where does the o-ring reside?
BT
blue thunder is offline
Old 01-17-2002 | 07:13 PM
formula31's Avatar
Post
Actually 2 o-rings. The distributor lower body had 2 cast collars that the oil supply for the lifters runs between. I think the MSD distributor has these collars fitted with o-rings too. The o-rings just cut down on the oil loss in a stock distributor to the lifters/push rods/rockers. The little hole allows some oil to lub the dost gear. Ut might be overkill. Im sure somebody has an opinion on it. I figure it was a good idea. I had the equipment to do it, so why not.
[ 01-17-2002: Message edited by: formula31 ]
tomcei
5
06-29-2006 09:03 PM
tomcei
9
06-05-2006 10:27 AM
carney
Fountain
2
10-14-2005 06:55 PM
Sates
2
04-13-2005 01:18 PM
convincor
4
05-12-2003 06:01 PM
