need advise on new prop >
Old 12-03-2003 | 08:34 PM
frankm7
Default need advise on new prop
I recently purchased a 24 baja outlaw with a F.I 502 with a little work (?) i'm too easily hitting the rev-limiter at 5500 rpm, can anyone suggest a prop that would push more water without "lugging" motor, and at what rpm should i feel comfortable with the engine spinning W.O.T???
Old 12-03-2003 | 09:53 PM
HOUSTONPROP's Avatar
Default RIC 232
WHERE ARE YOU I could help some if I had a idea of what pitch prop you are currently running,but sounds as if you did some motor work too?
ric232 knows his stuff when it comes to both props and motors .
where are you ric.?Darin
HOUSTONPROP is offline
Old 12-03-2003 | 10:07 PM
H2Xmark's Avatar
the factory rev limiter on a 502 mpi/454mag mpi is at 5050 rpm's, unless someone remapped the ecm. what prop do you have on the boat now?
H2Xmark is offline
Old 12-03-2003 | 10:20 PM
Default frankm7
see,Mark h2x is another,there are so many guy's on this board that know motors like you can't beleive.
outdrives ,props ect. give them all your info and then everyone, will help get you dialed in.
Welcome to the site.
Darin
Old 12-04-2003 | 01:11 AM
Got to have a starting point for the current prop and engine hp.
Griff is offline
Old 12-04-2003 | 08:11 PM
I am not to sure of what prop to use but I like your tow vehicle, where did you get it
cooter01 is offline
Old 12-12-2003 | 07:45 AM
Question AM I MISSING SOMETHING HERE
COOTER01
FRANKM7
Semper Fi
Prop Talk
5
04-22-2005 11:18 AM
Ran-Dom 32
05-14-2003 05:16 PM
BAJA WILL
04-28-2003 11:27 AM
wes29
Powerquest
6
10-17-2002 05:57 AM
