Hook removal (again) >
Old 01-19-2002 | 10:59 AM
kook
Question Hook removal (again)
If you remove the hook from a v-bottom, can't you control the resulting porpoising (sp?) just by dropping the tabs down a bit?
Old 01-19-2002 | 07:27 PM
Post
You probably could but I will never remove hook from my bottom (BTW, a 29 Outlaw has major hook). OSO member "mr gadgets" said he removed the hook from a Checkmate he had and it became undrivable.
Look at sharpening the edge where the transom meets the hull side. Often this junction is rounded so that the builder can pull the hull from the mold easier. I have read that squaring off this junciton to a 90 degree angle can increase speed up to 3 mph.
29 OUTLAW is offline
Old 01-20-2002 | 10:11 PM
kook
Cool
ttt
Old 01-21-2002 | 04:56 PM
Post
Kook,
Started a thread like this in the BAJA owners forum. Seems that if you removed just a bit at a time you could see what is happening. What model of boat are you contemplating this operation on?
Tim T.
BadDog is offline
Old 01-21-2002 | 07:17 PM
kook
Post
Sunsation Aggressor, 25'.
Old 01-24-2002 | 08:34 PM
SledgeHammer's Avatar
Post
Originally posted by cpqtim:
<STRONG>Kook,
Tim T.</STRONG>
Just got a new Baja and am new to this site. How do find the Baja Owners forum?
SledgeHammer is offline
Old 01-24-2002 | 08:37 PM
traviss's Avatar
Post
Just scroll down the forums... you'll find all the boat forums..
welcome to the board
traviss is offline
Old 01-24-2002 | 08:49 PM
kook
Post
I peek in the Baja forum - thanks!
Old 01-24-2002 | 09:10 PM
kook
Post
Tim:
Took a look at 60 day history, and no sign of a thread on hook removal.
-mark
Old 01-24-2002 | 09:45 PM
Post
Kook,
Looks like I will be the guinea pig on this one! Planning to start slow and remove a little at a time. It seems that some hulls really need the hook and the others were put there to compensate for the standard as shipped hull and power. For instance the Force 235 was sold with anything from a 350 standard to a 502. Not all came equipped with trim tabs. For some hulls and general planning they elected to put a hook in?
Tim T.
BadDog is offline
