simulated diamond plate??
Old 12-08-2003 | 04:08 PM
dyno's Avatar
Charter Member #655
Default simulated diamond plate??
I'm building some cabinets for my garage and wanted to make the fronts look like Aluminum diamond plate but dont want to spend a fortune on the real thing....can you buy it made from plastic???
dyno is offline
Old 12-08-2003 | 04:09 PM
Indy's Avatar
Member #154
www.lonseal.com is the general url, here is the diamond plate...
http://www.lonseal.com/lonplate1.html
Indy is offline
Old 12-08-2003 | 04:13 PM
NASTY HABIT's Avatar
Where are you ? I have quite a bit I could spare some ...or you can usually get a 12ft by 4ft sheet for under $100.00 ...i paid 75.00 a sheet last time I bought it.
NASTY HABIT is offline
Old 12-08-2003 | 04:16 PM
dyno's Avatar
Charter Member #655
Looks pretty cool is it like Formica or on a roll like flooring?
If your boat has a sail do you ride a horse to the ramp?
dyno is offline
Old 12-08-2003 | 04:22 PM
Waterfoul's Avatar
Gone Fishin'
Cool stuff. What's it cost??
Waterfoul is offline
Old 12-08-2003 | 04:55 PM
Indy's Avatar
Member #154
It's like roll flooring, it could be bent around a large radius curve if you had to.
I don't remember the exact price, but I paid approximately $250 for a sheet that was 6x8, the two part epoxy mastic was included in that price. You can also use contact cement for some applications.
Indy is offline
Old 12-08-2003 | 05:43 PM
rmbuilder's Avatar
MarineKinetics
Is it available direct or retail?
Thanks,
Bob
rmbuilder is offline
Old 12-08-2003 | 06:22 PM
Indy's Avatar
Member #154
I bought it direct from Lonseal, Carol McMaster is your contact. I think there are some distrubuters here also. I think his name is Active Fun.
Indy is offline
Old 12-08-2003 | 07:01 PM
C_Spray's Avatar
Diamond Member #001
You might want to save yourself some trouble. Check out Gladiator Cabinets . They,re available at Lowes's and include everything from wall hanging strips to cabinets to rolling cabinets to (get this) refrigerators covered with simulated diamond plate. the cabinet below goes for $168.....
C_Spray is offline
Old 12-08-2003 | 07:03 PM
C_Spray's Avatar
Diamond Member #001
and:
C_Spray is offline
