diamond plate in the engine area >
Old 12-08-2003 | 06:07 PM
ST31's Avatar
Question diamond plate in the engine area
While I have the engines out of the boat I was thinking that I may have some diamond plate installed. Has anyone else done this to a 31SS? If so do you have any pictures? All advice appreciated.
Thanks,
ST31
ST31 is offline
Old 12-08-2003 | 06:19 PM
puder's Avatar
speel chekk this fokker!
i did it on my scarab and LOVE it. Gives me level ground to stand on while workign on the engein and provides me with traction plus its super easy to clean up!
Pardon me, while I whip this out!
puder is offline
Old 12-08-2003 | 06:35 PM
traviss's Avatar
I did it a few years ago..
traviss is offline
Old 12-08-2003 | 09:03 PM
candyman35's Avatar
Traviss,
Nice job!
Dan
candyman35 is offline
Old 12-08-2003 | 09:53 PM
Whitey's Avatar
Is that aluminum?
Whitey is offline
puder's Avatar
if you're in salt make sure to have it powder coated!!!!
puder is offline
Old 12-08-2003 | 10:11 PM
Madcow's Avatar
Fairly easy to use, Cleans well, makes a HELUVA lot of noise when you cut & grind it. Use earmuffs. Makes a nice improvement though. I would recommend it. BTW, this is in a 42SS.
Madcow is offline
Old 12-08-2003 | 10:15 PM
MitchStellin's Avatar
Nice job Traviss. That is one clean install.
MitchStellin is offline
Old 12-08-2003 | 10:30 PM
lucy's Avatar
ditto.
lucy is offline
Old 12-08-2003 | 10:40 PM
carter38's Avatar
how did you put it down mounting wise
carter38 is offline
