Acclerator Prop Delivers
EXCELLENT TOP END,MIDRANGE IS UNBELIVABLE,NO BLOW OUT TURNING,EXCELLENT BOW LIFT FOR REDUCED DRAG.PLANES OUT VERY QUICK.
How much for a 27 LH. I was looking for a 27 mirage plus. Would you recommend the Accelerator over mirage plus for a single engine V looking for more bow lift. Running a 26 bravo 1 at 5600 now. Thanks. You will get a lab job what ever I end up with.
At least that is the plan.
I have run smaller 3 blades and like the way the boat handles slightly better than with 4 blades. Just guessing on 3 blade pitch. I have a 28 bravo 1 and it works well but I would like a few more RPM and more bow lift. Runs about 5100 - 5200.
At least that is the plan. I have run smaller 3 blades and like the way the boat handles slightly better than with 4 blades. Just guessing on 3 blade pitch. I have a 28 bravo 1 and it works well but I would like a few more RPM and more bow lift. Runs about 5100 - 5200.
THE ACCLERATOR PROP DESIGN.
YOU bet this is the ticket,you could probably pickup up a Mirage plus LEFT HAND DIRT CHEAP ON E- BAY..
THATS YOUR BEST WAY TO GO probably a 100.00 or so and then we can convert it to the ACCLERATOR,Make sure it's a PLUS .
We are making some great deals right now,we appreciate your Business.
dealer cost on a Mirage is 369.00 no big secret,but being a left hand YOU CAN GET ONE CHEAP OR I,WILL DO IT FOR YOU.I have a 17 new mirage plus on e-bay starting at 25>dollars
and still cant give it AWAY.
GIVE ME A CALL /when your ready/ now is the time for a good deal on ALL PROP MODIFICATIONS.
27 left mirage plus 99.00 e/bay
there is a 27 Mirage plus on there right now with 11 hours left for 99.00 no current bids and the time is
4
4 central time ,
YOU BETTER HURRY !!!!!!!!!!!!!!!!!!!!!!!!!!!!!
YOU BETTER HURRY!!!!!!!!!!!!!!!!!!!!
27 LEFT mirage pluus on e-bay 99.00 hurry hurry!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
4
4 central time ,YOU BETTER HURRY !!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Houston Prop,
You guys sure have an awesome reputation on OSO. I have tried the Mirage's, and Spinelli's, now have 28 Hydros, good top end, but terrible blow out, sometimes can't plane regardless of method used (in rough water). Boat, Cig 30 Mystique (non stepped) 500 e.f.i.s, turning bravo's 1.5 @ 5050/5100, 82.1 G.P.S. Hydromotive recommends the flared rim extension, BUT says a speed loss is imminent. Should I try to find 30 mirage's, and have you perform the "accelrator" mod or what? I have seen the similar treads regarding this blowout, however not concluded a recommendation. Do you buy fast props, then install the rings to slow back down?
Thanks.
Thanks.
Thanks for the compliments, Have you tried BRAVO-ONE FOUR BLADE PROPS AT ALL??
I think a set of 30 highly labbed Bravo -ones with exhaust flange's cut back and tuned to your boat would be the best setup.
we do buy props, but not at this time of the year,we can work your hydros to reduce the blowout tremondusly.
3 blade props no what? are not the answer on your setup.
