A question for Houston Prop?? >
Old 12-13-2003 | 09:44 AM
Default A question for Houston Prop??
...my question is if you guys work on props for a volvo duo-prop drive? If yes then here is another question...I am running a C5 setup on my boat right now...this setup is perfect...it gives me good top end and good cruising speed, I have a C7 setup that came with the boat...this setup runs poorly...I was told that I can re pitch the C7 to run similiar to the C5?? Is this true or should I just put it in the classifieds?
Here's Johnny is offline
Old 12-15-2003 | 04:29 AM
just bringing the thread back to the top...??
Old 12-15-2003 | 07:13 PM
HOUSTONPROP's Avatar
Default pitch change on propellers
props can be repitched-yes but when you change the pitch on a prop you can only change a portion of the blade,so when you say similar,you are correct it will never be like the true factory pitch.bringing you up to date
let me know if you may have any more questions,probably best would to ask under TECHNICAL/QUESTIONS AND ANSWERS
HAPPY HOLIDAYS EVERYONE.
HOUSTONPROP is offline
excalibur al
164
05-18-2006 08:28 PM
razor1115
16
04-24-2004 02:10 AM
ccscarab
04-23-2004 05:42 AM
Blade38
03-28-2004 08:06 AM
