fuel delivery problem-regulators >
Old 12-13-2003 | 11:46 PM
timucin's Avatar
Default fuel delivery problem-regulators
will use holley 12-705-1 160gph electric fuel pump to feed two 850 cfm double pumper carbs on blower.
now i need a regulator which has;
one input and two outputs .
outputs have to be adjustable cause i want to have 8psi(hot) on each carb at idle.
my questions are:
-is this pump enough for this application?
-what regulator do i have to use? any brand and part number help would be perfect
thnx
timucin is offline
Old 12-14-2003 | 02:37 PM
You should be able to run a fuel distribution block off of the regulator. I don't know about the fuel volume though.
Griff is offline
Old 12-14-2003 | 03:11 PM
BTW, Every Holley regulator I have seen has 1 input and 2 outputs. Most are 1/2inch inputs with 3/8 inch outs. You my need more volume though.
Mallory does make a 1 IN and 4 OUT regulator that is adjustable from 4-12lbs and has larger IN's and OUT's.
Summit part # is MAA-4200.
If you use this, you can just run fuel lines to each bowl on the carb.
Aeromotive and Barry Grant also makes several designs with various configurations.
Griff is offline
Old 12-14-2003 | 06:05 PM
timucin's Avatar
thnx too much
timucin is offline
dkwestern
09-24-2007 07:07 AM
jryan26
1
03-16-2007 09:48 PM
BAD-HABIT
1
07-04-2003 09:47 AM
gmnhra
3
11-20-2002 01:38 PM
blown formula
0
07-19-2002 12:09 PM
