On the hose? >
On the hose?
On the hose?
Old 01-24-2002 | 07:36 PM
Raypanic's Avatar
Post On the hose?
When running the typical Mercrusier BBC on the hose can you turn on the water and let it flow without running the engine?
From lessions from my wave runner I always start the engine and have someone on the ground start the hose a couple seconds before I turn it over. If I do not have a helper and have to do it myself is there a danger of getting water in the exhaust like reversion by letting the water run first? Or is the system basically sealed with no worry.
I have 502 Mags x Stainless Marine with straight pipes.
Thanks - Ray
Ray
Raypanic is offline
Old 01-24-2002 | 07:46 PM
WILDTHING TAZ's Avatar
B-MAX REPAIR
Post
RAY REVERSION ONLY HAPPENS WHEN ENGINE IS IDLEING,AND ONLY WHEN PIPES DON'T HAVE ENOUGH DOWN FALL.IF PIPES HAVE TO SHORT OF FALL,WATER CAN WORK BACK UP PIPE AND FALL INTO EXHAUST VALE.(ONLY AT LOW RPM).YOU ARE FINE DONT WORRY. RON
WILDTHING TAZ is offline
bcfountain
6
07-07-2008 03:08 PM
P Offshore
05-19-2007 02:28 PM
dogghouse
07-31-2006 07:51 AM
SmallPP
0
02-23-2005 05:56 PM
