What ratio to get to 1.36??? >
Old 01-24-2002 | 09:12 PM
Post What ratio to get to 1.36???
I have a bravo xz drive with 1.50 gears right now.
What ratio would you use in a Imco lower to get a final ratio of 1.36 with out changing the upper gear set?
Garry is offline
Old 01-24-2002 | 10:01 PM
formula31's Avatar
Post
I might be wrong on this, but I think the only way to get to 1.36 is to change the upper gears.
formula31 is offline
Old 01-25-2002 | 07:13 AM
Raypanic's Avatar
Post
Yep uppers
Ray
Raypanic is offline
Old 01-25-2002 | 08:25 AM
CigDaze's Avatar
Post
I think that is also the case...If I remember correctly, the lower unit gears are 1:1(equal), so there's no reduction there.
CigDaze is offline
sterndrivespec's Avatar
Post
there are gear sets available from merc that will change your xr into a 1.36 or a 1.25.these are for the lower,[gearcase]i have them in stock if you need them
sterndrivespec is offline
Old 01-25-2002 | 09:04 AM
Post
The XR 1.5 has upper gears of 19/16 teeth and lower gears of 19/15 teeth. By changing the lower gears you can get the different ratios. New lower gears of 17/15 will give 1.3458 and new lowers of 16/15 will give 1.266.
cobra marty is offline
Old 01-25-2002 | 09:14 AM
formula31's Avatar
Post
Cool, learned something new today. Thats only the XR though right?
Old 01-25-2002 | 09:32 AM
CigDaze's Avatar
Thumbs up
you and me both f31
CigDaze is offline
Old 01-25-2002 | 04:55 PM
Post
that will work on the xz also.if you have a 1.36 xz you can end up with a 1.12 ratio
Old 01-25-2002 | 08:08 PM
Post
So with the Imco lower can you order it with the correct ratio to get me to 1.36 or is this a merc deal only?
Garry is offline
