building a stroker tall deck for a friend-help >
Old 12-23-2003 | 02:11 PM
timucin's Avatar
Default building a stroker tall deck for a friend-help
3969858....427T......68-84...4-bolt
this is tall deck;
what is the maximum bore we can take from this block?
what is the maximum stroke?
thnx for help;
timucin is offline
Old 12-23-2003 | 06:11 PM
timucin's Avatar
i know this sounds stupid but sorry;
what is the standart bore on this block?
i am trying to understand how much will be .125 more
thnx
timucin is offline
Old 12-23-2003 | 07:17 PM
tripps's Avatar
Std bore should be 4.250 !!! tripps
tripps is offline
Old 12-23-2003 | 08:16 PM
timucin's Avatar
4,375 max bore
4,375 max stroke
right?
so 525 cu.in maimum i can get from this engine
am i correct?
timucin is offline
Old 12-23-2003 | 10:09 PM
paradigm shift's Avatar
Bore maximum size really depends on how the block sonic tests. You can go 4.5" on stroke with a little work on clearance for the rods.
paradigm shift is offline
Old 12-24-2003 | 06:17 PM
timucin's Avatar
do i have to be very well experienced to do that? or simple work?
thnx
timucin is offline
Old 12-24-2003 | 06:42 PM
thnx
You don't have to be an expert but you need to know what your doing or you can weaken or worse ruin a good block. The blockk has some clearance notches now you just need more room. If it is a 427 truck engine block it is not clearanced enough for even a 4.25 stroke. Actually 4.0 stroke may need some grinding. You just don't want to grind any more than you have to. Before blocks became more available and priced better the 427 tall block was a popular block. It does not have the strength that a Dart or Merlin or a GM Bowtie block has. I am sure there is a web site that has some how to tips better than I could explain. Maybe someone else knows or I will check and see what I can find.
Check this site. Good information in the tech section. Look at article #34 on blocks.
http://www.rehermorrison.com/
Old 12-24-2003 | 06:52 PM
timucin's Avatar
thnx too much
timucin is offline
Old 12-24-2003 | 07:00 PM
timucin's Avatar
cool site, also scholl stuff may be i should go to course like that cause i am not planning to give -up hi-hp engines and there is noone around here to help me...
timucin is offline
Old 12-24-2003 | 11:26 PM
There are other sites with information like this also but nothing like hands on knowledge. Course might even pay for itself in the long run. I think it would be fun, wish I had the time.
