Cam upgrade
Old 12-26-2003 | 02:43 PM
seabeach's Avatar
Question Cam upgrade
Please help me select a cam!
Sonic 35ss.
461 cui.
9.5:1 compression ratio
rectangular port heads 990
weiand team G (looks like stealth) dual plane
Holley 850
Gil exhaust (silent choise).
Prefere hydraulic flat tappered (not roller lifters).
Takes a long time to look at all available cams (crane, comp, isky, ...), give me a shortcut!
/Goran
seabeach is offline
Old 12-26-2003 | 06:32 PM
Ric232
I'm no cam expert, but I do know that the short riser Gil Magnum Choice exhaust will hold you back (I have the same exhaust). The exhaust flows fine, but I think those risers can only accept very minimal cam overlap (if any), so your duration and LSA choices are going to be limited. If you run a Crane 168731, you would need to have it ground with a 112 or 114 LSA. You might get by with a 168721, but I think that's a significant drop in power from the 731. That said, you should still be able to make a lot of power.
Anyway, as I said, I'm certainly not a cam expert. So I'm very interested to hear what the smarter guys have to say.
Old 12-26-2003 | 07:37 PM
Pat McPherson's Avatar
Two good hydraulic flat tap cams are the crane cam found in Merc's 370,400,420,425,525... and Edelbrock's torquer cam. I don't have part numbers for you, but they can be found easily on their web-sights.
Both have 114 LSA so the overlap is minimal; there won't be any problems with your exhaust.
Patrick
Pat McPherson is offline
Old 12-26-2003 | 09:51 PM
Erson JB 100 on a 112+4
Specs are 228/235 @ .050" with .540" lift.
I have used this cam on a couple of motors very similar to yours and it works great. Prop for 5200 to 5500 max.
No reversion with stock manifolds! Very good power from 2500 to 5500.
WETTE VETTE is offline
Old 12-26-2003 | 10:55 PM
formula31's Avatar
I use the Edelbrock torker cam for very similar engines with good success. I have the same exhaust. That cam is 224, 232, .527, .553 on a 114 seperation.
formula31 is offline
Old 12-27-2003 | 10:37 AM
I have 2 hp420 cam's and lifters in perfect cond., if interested
JMPH
JMPH is offline
Old 12-27-2003 | 03:16 PM
seabeach's Avatar
Does someone know the Crane part number for Merc's 370,400,420,425,525 cam?
Thanks!
Goran
seabeach is offline
Old 12-27-2003 | 03:54 PM
rmbuilder's Avatar
MarineKinetics
Goran,
Merc # 451-7892
Crane Part #132561.
Here is the spec card for that cam.
http://dab7.cranecams.com/SpecCard/D...1=Display+Card
Bob
rmbuilder is offline
Old 12-27-2003 | 04:05 PM
seabeach's Avatar
JMPH, please let me know the price?
photos?
/Goran
seabeach is offline
Old 12-27-2003 | 04:06 PM
seabeach's Avatar
Thanks Bob!
seabeach is offline
