New 260 Owner >
New 260 Owner
New 260 Owner
Old 12-27-2003 | 10:17 AM
FlashPRace's Avatar
Default New 260 Owner
Second time Velocity owner. This time it's a 260 with 7.4MPI. Runs nice but like everyone would like more. Is it there anything worth doing to this motor or best to replace with a MAG HO ?
FlashPRace is offline
Old 12-28-2003 | 08:34 PM
mikes280's Avatar
buy a 502 500 crate motor from you chevy dealer it will wake it up
mikes280 is offline
Old 12-30-2003 | 03:40 PM
Revelocity's Avatar
I had good luck ProCharging the 7.4MPI's in my previous boat - 320. You'll be at about 500HP at the crank. I have one kit left in case your interested.
Revelocity is offline
Old 01-07-2004 | 10:42 AM
carney's Avatar
pro charge it . If you have the need for speed. {do it right, or do it twice}
carney is offline
Old 01-07-2004 | 11:38 PM
kidrock is offline
Old 01-15-2004 | 07:02 PM
velocity260's Avatar
I have the same boat runs good but I hear you just needs a little more power. I put one of the labbed bravos props from the factory that helped a little.
velocity260 is offline
Old 01-16-2004 | 01:53 PM
FlashPRace's Avatar
Thanks for the help. Would pro charging change reliability?
What Bravo Prop was used I'm turning a hydromotive 4 blade 24 right now. (stock I assume)
Old 01-16-2004 | 04:15 PM
Call the factory they can get one of their labbed bravo's they use on their race boats. Gives you better hole shot and will not slip on you on turns or acceleartion. My hydro slipped alot just as the boat planned then some times in turning over waves.
Old 01-16-2004 | 04:30 PM
Revelocity's Avatar
With regard to Procharger and reliability - over the short term (3 seasons) I didn't have any reliability issues. Over the long term, it's logical that the blower motor will wear out faster but of course it depends on how it's used.
echap
Powerquest
10
12-09-2007 11:21 AM
BUIZILLA
07-05-2007 03:08 PM
tzrider
Velocity
12
08-24-2006 09:39 PM
HOTTZU98
Powerquest
16
12-05-2005 09:22 PM
boomer
06-07-2005 02:38 PM
