Valve Cover Gaskets >
Valve Cover Gaskets
Valve Cover Gaskets
Old 01-29-2002 | 09:17 AM
IRONMAN's Avatar
Post Valve Cover Gaskets
Cork vs Rubber, Who likes what and why?
AND do you like to apply additional sealant?
what type?
IRONMAN is offline
Old 01-29-2002 | 09:36 AM
Crazyhorse's Avatar
Post
I prefer cork but Felpro makes a really nice neoprene gasket with a metal stiffener in the center. They're around 40 bucks but last forever.
Crazyhorse is offline
Old 01-29-2002 | 09:43 AM
David's Avatar
Post
I have the rubber/steel ones. installed dry, no leaks, reuseable, no complaints.
David is offline
Old 01-29-2002 | 10:19 AM
Post
Dont mess around get the rubber gaskets I'm still using mine from 5 years ago and thats taking them on and off about 4 times a year. (cant leave anything alone) Cork gets hard and brittle I found in a couple of years. I like to clean with brake cleaner or carb cleaner, put some on a rag and wipe the surface of the two contact areas and install dry.
P.S the steel inserts are great you can never over tighten them and squish the rubber out
tahoez71 is offline
Old 01-31-2002 | 06:26 PM
Iggy's Avatar
Post
Unless you plan on removing them on a regular basis, I'd through away the gaskets and use Permatex Ultra Copper gasket material (red RTV). My old truck had the hardest covers to seal until I used that stuff. Drove it for 80k miles with out a leak. I wouldn't use anything else.
Iggy is offline
Scarab3DMC
11
09-02-2008 12:58 PM
boatman22
7
06-26-2008 05:08 PM
CN24
7
12-23-2004 06:19 PM
klaw
1
11-07-2004 06:08 PM
mercruising
11
03-04-2004 12:53 PM
