Carb Help??? >
Carb Help???
Carb Help???
Old 12-30-2003 | 11:54 AM
Swede's Avatar
Default Carb Help???
I just purchase a 1999 30' Spectre with 509's putting out around 540hp. The boat has Dominator 4500 series(#8896) 1050cfm 3 circuit carbs which I have come to find out probably are not the right carbs for my application(Unless I want to go broke on fuel and plugs). I guess they are design to run idle to wide open. Very rich in between
Does anyone have experience with these carbs? Anyone know a way to make them work? The guy at Holley said if I get them to run good at midrange they will be lean at wide open.
What would be a good carb for my application?
Anyone know of a good website to trade carbs?
Swede is offline
Old 12-30-2003 | 09:37 PM
homan
Probably 830 or 850 jetted to your motor. HP 500's use a 800
Old 12-30-2003 | 09:54 PM
Tricky919's Avatar
I have a 502ci with 547 hp and i run an 830cfm holly carb with 98 jets, i will check the air bleed size and get back to you.........
Tricky919 is offline
Old 12-31-2003 | 06:38 AM
Swede's Avatar
Thanks!
What is the Holley part# on your carbs? Are they mechanical or vaccum secondaries? Which is better for boats?
I found someone that will trade me for a pair of rebuilt Holley 850 (#4781) Double pumpers. Any thoughts on that carb?
Is there any benefit in trying to find the actual Holley MARINE carbs?
Dave
Swede is offline
Old 12-31-2003 | 02:48 PM
Holley HP830cfm or maybe some HP950cfms will probably be the best. Mechanical secondaries work best on boats. Both come in marine versions.
You should definately use MARINE carbs. Its a safety factor. They are set up with J-tubes and different shaft seals so they won't leak any fuel externally.
Griff is offline
Old 01-01-2004 | 07:25 PM
John B's Avatar
Try this web sight. He is one of the best!http://www.nickersonperformance.com/
John B is offline
tssteph
Wanted
2
07-31-2008 08:14 AM
horsepower452
3
06-09-2007 06:54 AM
East Coast B
4
07-08-2005 03:57 PM
Dean Ferry
05-15-2002 02:00 PM
