2004 30 baja outlaw ? >
Old 01-04-2004 | 10:43 AM
26sonic's Avatar
Default 2004 30 baja outlaw ?
what true gps speeds will this boat run with 496 ho's ? dealer says 80 + ?
26sonic is offline
Old 01-04-2004 | 11:00 AM
The debate rages over on TBM. Go have a look. Nobody can agree on how fast, nonetheless, I think we would all agree that over 80 bone stock ain't happening. I'm sticking with 77-78 from the factory with 28" 4 blade props and my guess is on the high side compared with what many other are guessing.
29 OUTLAW is offline
Old 01-04-2004 | 04:06 PM
105mph_38_2003's Avatar
Performance chart
105mph_38_2003 is offline
Old 01-04-2004 | 04:07 PM
Time To Plane: 5.1 sec.
0 to 30: 6.7 sec.
Test Power : 2 x MerCruiser 496 MAG HO
Transmission: Bravo I Z
Ratio: 1.5 :1
Props: 28'' 4-blade stainless steel
Load: Load: 2 persons; Fuel: full; Water: none; Gear: minimal
Climate: Temp: 85 deg.; Humid: 88%; Wind: calm; Seas: 1-2 ft.
Old 01-04-2004 | 04:08 PM
RPM MPH Total GPH MPG Range dBa
600 4.0 3.2 1.25 1.09 139 74
1000 8.2 5.9 1.38 1.20 154 75
1500 9.7 10.2 0.95 0.83 106 80
2000 11.1 19.2 0.58 0.50 64 84
2500 30.8 20.5 1.50 1.30 167 85
3000 42.2 25.5 1.65 1.44 184 88
3500 52.5 34.6 1.52 1.32 168 90
4000 67.0 58.0 1.16 1.00 128 95
4500 70.5 61.3 1.15 1.00 128 95
4850 70.8 65.1 1.09 0.95 121 96
Old 01-05-2004 | 07:30 PM
liquid asset's Avatar
I don't see a 10 mph diff from mags to ho's, a 33 only gets about4-5 mph
liquid asset is offline
Old 01-06-2004 | 05:03 AM
BURNSMAZZ's Avatar
I would have to agree with Asset,I don't see a 10mph swing between motors.
BURNSMAZZ is offline
Old 01-06-2004 | 08:34 AM
Originally posted by GottaHaveIt
Uh, there's not only a difference in propshaft HP. There's also a difference in the max operating RPM.
425 HP 4600-5000 RPM operating range 28 B1 prop
375 HP 4400-4800 RPM " " 26 B1 prop
RPM limitation is my main beef with 496 non-HO. Peak HP on that engine is seen at only 4600rpm. This is reminiscent of the old anemic 7.4mpi. On a 454mag, 502mag, and 496HO, peak HP is seen at 5000rpm. Heck, even on the new 6.2, it's at 5000rpm.
Old 01-06-2004 | 06:23 PM
garshev's Avatar
I really have to wonder what all the hype over the 30 is all about. The 29 with the 454mags ran 70 tops and i've been in more than one. the 29 with 500's ran 78 tops and i've been in that one also. The 30 weighs considerably more and the boattest.com says 70.8 gps.
what's not to believe?? Baja typically overprops their boats from the factory and if 4600 rpm is really all the 496mag is rated for then at 4850 (the rpm on the boattest.com report) it would have been against the rev limiter. It had to have the H.O. motors in it> the temp was 85 with 88% humidity which is hardly optimum for speed runs but seems like it ran as i would expect it to for the conditions. You have to realize that gps speeds vs somebody told me speeds are two different animals.
garshev is offline
Old 01-06-2004 | 06:42 PM
Originally posted by garshev
... the 29 with 500's ran 78 tops and i've been in that one also.
There's a member on this forum who has a 29 with 500EFI's. He's running 82mph.
