540 Cooling
Old 01-04-2004 | 05:59 PM
RLW
Default 540 Cooling
To all you 540 owners out there and anyone else of course, may I ask what size oil coolers you are running?
Is anyone using a crossover instead of a recirculating pump?
What size T-stat and have you drilled any holes in it?
As always, thanks for any replies.
Russ
RLW is offline
Old 01-04-2004 | 06:34 PM
KNOT-RIGHT's Avatar
I have been running 540s N/a 9.5 to one
merlin heads, single plane merlin intakes, dominators
Crossover tubes, water jacketed headers no tstats
raw water cooled
the oil coolers are a old gil savage 5'' x 12 inch
similar to a hardin marine.
100 degree water temp
220 oil temp
Gerry
KNOT-RIGHT is offline
Old 01-04-2004 | 06:38 PM
KNOT-RIGHT's Avatar
Before the single planes. I had dual planes with t-stats
160degree
had to drill two eighth inch holes to get the temp
to stay steady at around 120.
Old 01-04-2004 | 09:33 PM
hey caveman what kinda hp you getting outa your combo
carreraboat is offline
Old 01-05-2004 | 01:07 PM
KNOT-RIGHT's Avatar
never dynoed.
I would assume from some of the dyno sheets I have seen
I would say conservably speeking 580 to 600hp
That combo was:
540 bowtie tall decks
Bryant racing cranks 4.250
4.5 bore
Ross 9.5 to one forged pistons
139741 crane hydraulic roller cam
Merlin cast iron full ported heads
merlin single plane intakes
4500 dominator
Old 01-05-2004 | 01:18 PM
454hoho
Default caveman
What kind of boat 32 hustler???? two 540`s??? what kind of top speed are you getting/just curious but t have simular setup.
Sorry for interrupting
Old 01-05-2004 | 01:22 PM
Official OSO boat whore
I think mine are 3x12 with a thermostat.
Cord is offline
Old 01-05-2004 | 01:55 PM
KNOT-RIGHT's Avatar
Default Re: caveman
I dont wanna Jam all over this guys thread.
Runs 101gps full tanks of Fuel its a 1985 Hustler le 32
with Arneson ASD-8,s
http://www.offshoreonly.com/forums/s...uch+horsepower
Old 01-05-2004 | 05:07 PM
RLW
Cord,
What kind of T-Stat? Oil or water?
What power are you running? 540?
It's normal to get off track on these threads. No big deal.
Thanks for the feedback.
Where's JimV, Kaama and Monty?
Russ
RLW is offline
Old 01-05-2004 | 05:32 PM
Yea, it's a 540. Dynoed at 580hp with 100 degree temps in the dyno room. I'm using the perma-cool oil thermostat. I had the lines reversed at first and never saw oil temps until I ran the boat hard. Then they would climb and fall off immediatly. With the lines reversed so the thermostat was working the temps now rise quickly and are very stable.
I'm using a stock merc water thermostat. 140 degrees? Because I'm not using the stock circ pump, I never see any engine temp unless the water is real warm. Then I'm seeing what I assume to be 140 degrees.
Cord is offline
deerob5000
5
02-20-2008 05:54 PM
sandcraft
10
04-05-2006 09:44 PM
Nealzy
4
08-14-2005 11:14 AM
SmallPP
0
03-16-2005 02:28 PM
SouthernExposure
2
02-18-2004 10:54 AM
