timing chain cover swap >
Old 01-04-2004 | 06:49 PM
homan
Default timing chain cover swap
I was going to switch timing chain covers from stock to aluminum, I noticed I have 2 timing pointers 1 on the cover and 1 on a bracket that goes to the sea pump and alt. which is slotted for adj. Question is how accurate can the slotted on be and does pan have to be dropped to change cover, motor is a 95 502
Old 01-04-2004 | 06:59 PM
MACDAD260's Avatar
Charter Member #818
If you are confident that the current timing pointer is correct then start by turning the crank so that the groove on the balancer lines up with zero on the pointer. Then when you reinstall the balancer you will be able to check if the new pointer lines up. If you do not remove the oil pan you may have to modify the area around the outer edges of the pan sealing area on the timing cover to get it to fit. This is easy on a stamped pan. I don't know how difficult it will be on the aluminum one.
MACDAD260 is offline
Old 01-05-2004 | 12:55 PM
PatriYacht's Avatar
You have a Gen 5 engine just like mine. The oil pan gasket is one piece including under the timing cover. Almost for sure the gasket will break when the cover comes off. Save the pieces and use lots of silicone seal when you put the cover back on. I've been looking for a 2 piece timing cover to get around this problem. Anybody know of one that fits a Gen 5?
PatriYacht is offline
Ran-Dom 32
Wanted
1
03-15-2008 07:06 AM
OhioRiverCigarett
7
11-13-2006 05:14 PM
tomas_wallin
7
05-26-2005 02:06 AM
boatn70
5
11-18-2004 01:14 PM
kennyo
9
07-28-2004 09:21 AM
