Hydro Four Blade
Thank You first of all for trusting us and letting Houston Prop to work on your propeller.
you bet ,I will check in the computer and see what your prop was and what exactly was done to it,as far as performance changes ,obviously we can see the cosmetic side
if this is your prop I just cant remember all the props with real names and screen names.
it's very confusing at times but I WILL GLADLY GET YOU A PROP AND A GREAT PRICE.Thanks again and I will talk to you soon,Darin
if this is your prop I just cant remember all the props with real names and screen names.it's very confusing at times but I WILL GLADLY GET YOU A PROP AND A GREAT PRICE.Thanks again and I will talk to you soon,Darin
Darin,
My boat runs faster with the 3 blade mirage. The problem is that it wont plane off with out ventilating(prop is new never damaged). If Im careful and feather the throttle and lay the boat an one side of the "V" it will go but thats the only way it will plane. Do you think the drive is high? Is that a problem that can be fixed? Also my 30" bravo needs a little slip out of the hole/needs to pick up speed a little quicker or the motor bogs on the power valve. What can be done with that? Greg 815-218-1603
