Range Of Rpm On 454ci
Hopefully you guys can help me out here. I was wondering I have a 31' 1979 Excalibur t-454 400hp motors trs drives 23p mirage 3-blade. does anybody know what the RPM range should be for these motors? right now the most I can get out of them is about 4700rpm ??
Most likely the rpm is down due to weak valve springs, they will make a very effective rev limiter
I`m sure the valves aren`t sealing too well either.
800 hrs, they have had a good life. Time for good old 'look see'
I`m sure the valves aren`t sealing too well either.800 hrs, they have had a good life. Time for good old 'look see'
And weak valve springs spells disaster at elevated rpms. Valves won't get enough seat time to cool properly. A valve job with a checking of the springs is minimun to avoid disaster. Also will give a nice chance to service the exhaust system.
Dave
Dave
