cam specs on 496 magnum
496 mag Roller Tappet Camshaft
Lobe Lift
Exhaust - .284 in.
Intake - .282 in.
Journal dia. 1.9477 - 1.9479
Camshaft Roundout .002 in.
496 mag HO Roller Tappet Camshaft
Lobe Lift
Exhaust - .30 in.
Intake - .30 in.
* Duration Not Avail...
What ya doin?
Lobe Lift
Exhaust - .284 in.
Intake - .282 in.
Lobe Lift
Exhaust - .30 in.
Intake - .30 in.
What ya doin?
I've cam doctored both cams and L8shift has good numbers. The duration on the 496HO is 222 degrees on the intake and 232 degrees on the exhaust @.050. Not a radical lumpy cam. The reason this motor dosn't make bigger numbers is the stock iron heads. Our aluminum heads will premier at Miami in February and we should be shipping pairs in late March. Now you will be able to make this engine roar!
Raylar
Raylar
