exhaust question please help
hey guys, well I am adding EMI thunder manifolds with the short stainless risers to my boat, it has the corsa capt call exhaust, my problem is when I pulled my silent choice pipe and looked down the Y pipe for the through prop, the flapper in the Y pipe [through prop] is damaged, I looked at Bam's site to see if he had them [no] ,so I need a part number are info on where to pick these parts up at . thanks
Mark R
they are the newer style 2 piece flapper if that helps
Mark R
You're in luck! I know nothing about that, BUT the March issue of Family and Performance Boating is out and they had the same issue while doing an exhaust upgrade. The part number they have in the article is for the 2 piece flapper. Part number is 807166A. (Mercury Marine). Hope this helps.
Paul
Paul
