Best way to remove vinyl grafphics? >
Old 01-22-2004 | 08:16 PM
kmiller's Avatar
Default Best way to remove vinyl grafphics?
I picked up my new boat on Tuesday. It was only 7 deg outside, Michigan weather. Well I plan to re-due some of the stickers on the boat, not sure whats the best way to remove the old ones. I tryed the heat gun and finger nail but could take for ever! Well let me know what will work, thanks Kyle
Attached Thumbnails Best way to remove vinyl grafphics?-scarab-full-size.jpg
kmiller is offline
Old 01-22-2004 | 08:19 PM
glassdave's Avatar
Neno the mind boggler
3M makes a wheel you put on a drill that takes them off. wokrs pretty good just be careful. . .nice ride by the way. . . . congrats
08 OPA High Points Champion
glassdave is offline
Old 01-22-2004 | 08:23 PM
kmiller's Avatar
some if the sickers are over paint or vinyl and not glass. will this still work?
kmiller is offline
Old 01-22-2004 | 08:24 PM
Ryan Beckley's Avatar
Racer
Racer
heat gun and finger nails. the eraser dave is talkin about works too.
Ryan Beckley is offline
Old 01-22-2004 | 08:25 PM
Fightclub
kmiller...
Nice boat congratulations... PM Sean Stinson he just took mine off this week.
STS HIGH PERFORMANCE
Old 01-22-2004 | 08:55 PM
Official OSO boat whore
I know of the eraser, but I've never tried.
My .02...I like that graphic. It works with the lines of the boat extremely well. Kinda reminds me of the blackhawk donzis.
Cord is offline
Old 01-22-2004 | 09:01 PM
Ted G's Avatar
Actually the hair dryer and peeling it works pretty fast once you get it warm and going. I would not try it right now But once it starts to lift use the hair dryer to keep the joint where the sticker and the hull warm and it will lift right off.
www.cbpba.com
Ted G is offline
Old 01-23-2004 | 07:12 AM
fastedy's Avatar
then use goof off/goup off snot sure of the spelling, to get the glue off. Ryan if you use anything better please let un know, I just stripped my boat for the 4th or 5th time.
Eddie
"If Things Seem Under Control, You're Not Going Fast Enough"
Mario Andretti
fastedy is offline
Old 01-23-2004 | 07:23 AM
kmiller's Avatar
the bad part is some of the stickers are so old that they are dry and cracked into small pices. It's a pain in the a**. the last person put new vinyl over them, not vary professional.
kmiller is offline
Old 01-23-2004 | 07:50 AM
THE GOOD STUFF's Avatar
HEAT GUN &PLASTIC PUTTY KNIFE WORKED WELL FOR ME . THE I USED ACETONE TO REMOVE THE GLUE... GOOD LUCK
THE GOOD STUFF is offline
