prop nuts
Old 01-23-2004 | 12:45 PM
seahawk's Avatar
Default prop nuts
should brass or stainless be used on a stainless shaft and why?
seahawk is offline
Old 01-23-2004 | 01:30 PM
mikev's Avatar
should be stainless if use brass it will cause corrosion due to being to different types of metal.
mikev is offline
Old 01-23-2004 | 05:57 PM
Comanche3Six's Avatar
If you go with a stainless nut on a stainless shaft use plenty of lube on the threads. Ss nuts on ss threads will gall and lock up tight. Use marine grease.
Comanche3Six is offline
Old 01-23-2004 | 06:31 PM
Reed Jensen's Avatar
Use brass... less chance of galling.... although the brass and stainless are dissimilar.... the brass doesn't react to electrolysis like aluminum or lighter metals. If you use stainless....chances are they may at some time begin to gall... then you are looking at replacing the propshaft. I had brass nylok nuts on my boat... never galled... never seized... never corroded.. and they were used almost exclusively in salt water for over 10 years.
Reed Jensen is offline
Old 01-27-2004 | 11:37 AM
seahawk's Avatar
ttt
seahawk is offline
masher44
Prop Talk
6
07-28-2008 09:35 PM
BraceYourself
04-17-2006 02:13 PM
glassdave
09-08-2005 01:29 PM
