7.4 compression ratio >
Old 02-03-2004 | 07:06 PM
daveo1
Question 7.4 compression ratio
Does anyone know the stock compression ratio of a 1999 7.4mpi (L29) motor? What is the volume/CC of the heads? any info would be appreciated.
Old 02-03-2004 | 07:38 PM
Pat McPherson's Avatar
Heads are 100cc.
Compression 9:1.
Adding a little punch to one myself...
Patrick
Pat McPherson is offline
Old 02-03-2004 | 08:09 PM
daveo1
Pat, are you using the stock heads or are you going aftermarket? I have decided to go with some Merlin oval ports, 119 cc. I need to figure out what machining I need to do to stay around 9:1 CR.
Old 02-03-2004 | 08:23 PM
Dave,
I am staying with the stock heads.
To get 9:1 with the 119cc heads you will need to change out the flat top pistons.
I did the swap on my old 330.
$250 will get you a set of Kieth Blacks or Speed Pro Hypos...
Patrick
Old 02-03-2004 | 08:26 PM
daveo1
How about milling the head a bit?
Old 02-03-2004 | 09:36 PM
I'm interested in this question also. Bought some used large oval 781 heads on e-bay. Want to increase compression ratio from stock 8:1 up to ~ 9:1. 118cc chambers. What are the relative merits of domed pistons vs milling heads? How much can you mill before you get into trouble?
bago Baja is offline
Old 02-03-2004 | 10:10 PM
homan
i think if .040 is taken from the head that will raise you to 9:1
Old 02-04-2004 | 09:17 PM
Not sure if you can mill that much on a Gen V or VI head, but I think the older heads have more meat...
I needed new pistons on my 330 so I used domed.
Patrick
bcarpman
2
09-03-2006 08:59 PM
danielthelen
5
05-09-2005 02:44 PM
danielthelen
1
02-20-2005 07:57 AM
seahawk
2
05-24-2004 12:21 PM
HARRISONMIRAGE
1
12-13-2003 07:17 PM
