496 MAG secrets????? >
Old 02-05-2004 | 03:24 PM
Default 496 MAG secrets?????
I am looking for simple quick HP gains from the 496 MAG. I currently run the 2002 375HP and complained about the leaking soot; Merc. sent a re-programed ECM / PCM to lean the engine. Sounds like a good start; should I supplement with a K&N air filter?? Are there internal plastic / rubber inserts / baffles in the capt.call that could be removed??? ANY HELP FROM YOU 496 MAG OWNERS, WHO HAVE TRIED EVERYTHING, WOULD BE GREATLY APPRECIATED!
caravelle260 is offline
Old 02-06-2004 | 07:24 AM
ccarloss's Avatar
Here's a couple of ideas. Not the cheapest ideas though?
http://www.procharger.com/marine/M_496.shtml
http://www.whipplesuperchargers.com/...sp?ProdID=1149
ccarloss is offline
Old 02-06-2004 | 07:46 AM
THANKS ccarloss! I have checked them out, not really for the ILLINOIS River. I am just looking to find hidden Hp.
LAB THE PROP?????
K&N Air Filter???
Baffles in the "Y" exhaust???
Larger pitch???
Again -- I am running 496 MAG @ w.o.t. 4850rpm. 22P Mirage. 25'7", 4350# dry. 67 mph under typical conditions; LOOKING TO BREAK THE 70mph MARK.
Old 02-06-2004 | 07:59 AM
dhlaw's Avatar
Lab your props.......
dhlaw is offline
Old 02-06-2004 | 08:52 AM
PatriYacht's Avatar
Horsepower costs money. Howfast do you want to go?
PatriYacht is offline
Old 02-06-2004 | 08:58 AM
Just looking for the extra HIDDEN 3-5 hp I know is there; I only want to break that 70 MARK!! 3-4mph away. ANYONE TRIED THE K&N element????
Old 02-06-2004 | 09:33 AM
3 to 5 HP isn't going to get you to 70. The K&N element might get you 1/2 MPH, or then again it might add nothing. But it will look really cool and the cool factor is worth a lot!
Someone said lap the prop - probably the surest approach far 2 - 3 MPH
Reddog is offline
Old 02-06-2004 | 11:30 AM
Pat McPherson's Avatar
Cam and ECU change to make it a 425HP Mag. HO...
Patrick
Pat McPherson is offline
Old 02-06-2004 | 11:44 AM
67? Is that GPS or speedo?25' with a Mag going 67 is pretty stout.You may be further away from 70 than you think.BOB
Bob280Silencer is offline
Old 02-06-2004 | 11:49 AM
Caravelle,I just noticed that you have a 26 Caravelle.My buddy has same set-up.On a good day with him & his wife,full tank,maybe 60!
