502 Mag (root, whipple or Centrifugal) >
Old 02-07-2004 | 09:06 AM
Cat-n-Around's Avatar
Default 502 (Roots, Whipple or Centrifugal)
Having a pair of 502 Mag's rebuilt and going to add a supercharger not sure witch way to go roots (871), Whipple or Centrifugal. If I go centrifugal it's going to be a Vortech, I like the fact they keep the stock cooling system. I want to make approx. 650 reliable Hp (looking for pro's and cons).
Cat-n-Around is offline
Old 02-07-2004 | 10:50 AM
Are they carbed or EFI?
tomcat is offline
Old 02-07-2004 | 10:53 AM
They are complete 502 mag's so they are EFI but thats easy to change now.
Old 02-07-2004 | 08:31 PM
As you debate the pros and cons, take a look at our website, www.rtechperformance.com.
tomcat is offline
Old 02-08-2004 | 07:43 AM
When are you going to have the EFI version out?
Old 02-09-2004 | 09:48 AM
Cattitude's Avatar
I've been running the whipple system for 3 yrs on my 454magefi on my 01 Daytona- can't say enough good things about it. Pm me, I can hook you up!
Cattitude is offline
Old 02-10-2004 | 08:12 PM
ttt
Old 02-12-2004 | 02:00 PM
SummerObsession's Avatar
I had VERY poor luck with a whipple kit on a 502 MPI.
Unless they have worked out the bugs, I wouldn't recommend it. I have heard great things about their other kits though.
R-tech does have their act together as it appears to me, worth a very serious look.
SummerObsession is offline
Old 02-12-2004 | 08:38 PM
Default cooling system mods?
I didn't realize the cooling system needed to be modified for a pro-charger. I'm evaluating systems too... what needs to be changed?
thanks
pantera38 is offline
Old 02-13-2004 | 06:01 AM
Basically you remove the water circulating pump, install a cross over and remove the thermostat. If you end up running a thermostat you will have to run some type of dump valve. Wette Vettte has a nice set up, thats what I used on my old boat.
