Merc Oil Filter Study >
Old 02-07-2004 | 10:30 PM
Grease
Thumbs up Merc Oil Filter Study
I saw some posts here earlier about Merc oil filters. I am a pleasure boater with a Merc I/O. However, our filters are the same that many of you use.
I took 12 filters apart and analyzed them -- complete with pore size and flow measurements.
These filters map to the venerable AC Delco PF1218.
I have not tested the Merc Racing long version.
Coming soon will add the following filters:
Donaldson
Fleetguard
Amsoil
Mobil 1
Enjoy! Let me know what you think. Since I can't post a URL until 10 posts, you can cut off the Z on the front of this one.
Zhttp://home.earthlink.net/~memphis3/mercfilters/merc.htm
Grease
Old 02-07-2004 | 10:47 PM
bob
Charter Member #40
Excellent info! Wouldn't by chance have any data on Wix 51222R ?
bob is offline
Old 02-08-2004 | 06:35 AM
nice work!!
we use K&N
audacity is offline
Old 02-08-2004 | 10:39 AM
US1 Fountain's Avatar
Ginger or Mary Ann?
Default Re: Merc Oil Filter Study
Great info, thanks!
Since I have a little more than 10 post, I can post the URL:
http://home.earthlink.net/~memphis3/...lters/merc.htm
US1 Fountain is offline
Old 02-08-2004 | 10:42 AM
Ric232
It looks like the "ratings" consider flow but not filtration. Am I missing something ?? Seems like the Merc filter has very good flow considering its small pore size (= good filtration).
Old 02-08-2004 | 12:13 PM
Grease
I haven't had the pleasure of dissecting a WIX racing yet. I hope to add it to the list.
Old 02-08-2004 | 12:19 PM
Grease
Originally posted by audacity
nice work!!
we use K&N
Thanks. In my opinion in this application, the K&N is a great filter. It has smaller pore size than the Merc, yet it has more media, hence more flow. I wouldn't loose sleep over using a WIX, Hastings, or Baldwin in a boat. I would be a little concerned over the AC or PureOne in a boat regarding flow -- but the filtration is excellent. They may flow enough once the oil is hot, but may be in by-pass mode longer than the others.
I may even use a by-pass filter in addition to a good flowing filter. That way you get the benefit of both worlds.
We are going to test some synthetic filters from Donaldson, Fleetguard, and Mobil 1 soon.
Old 02-08-2004 | 12:22 PM
Grease
I made up my own rating system. They do consider flow and pore size. You can modify it to suit your emphasis (weighting system) regarding the different characteristics and come up with your own winner.
The Merc has great flow but has the largest pore size. I also wonder if the large pore size has to do with the concern if water gets in the oil it can swell the pores.
I'm sure many of you use the large canister Merc racing. I'll have to get that one and test is also. I'm assuming that the media is the same as the small canister Merc, but you never know until test time.
Old 02-08-2004 | 01:09 PM
blue thunder's Avatar
Wow, that is good info. Interests me because I just blocked off my bypass valves in the remote filter pad. Would be nice to know the different bypass pressures of these filters.
Looking forward to the synthetic media filter testing!
Dave
blue thunder is offline
Old 02-08-2004 | 02:46 PM
Grease
Originally posted by blue thunder
Would be nice to know the different bypass pressures of these filters. Dave
None of these filters have bypass valves. That is part of the engine. GM didn't want to rely on the filter to do the bypass, so the engine does that function. Physically, I'm not sure where the bypass is located.
Grease
