What SBC valve springs do I need? >
Old 02-08-2004 | 06:53 AM
dma251
Default What SBC valve springs do I need?
I just ordered a comp xe-262 cam- I know I will need new valve springs for my 1990 350 which had the stock cam/valve springs in it. What springs should I get, and do I need new retainers? obviously I should replace the seals- which ones should I get? I don't want to spend a ton of money, but I don't want junk either.
Can anyone advise me on this?
Old 02-08-2004 | 08:29 AM
traviss's Avatar
Comp should have Part #'s for the springs, retainers, locks, seals that match that cam. Just call comp cams and tell them what cam you have and they will advise which springs and ect, you should run. You could also look on there website. I run crane and their website has all the info.
traviss is offline
Old 02-08-2004 | 04:29 PM
robyw1's Avatar
Use Comp Cams springs part number 981-16 or even better 986-16
Roby
robyw1 is offline
Old 02-10-2004 | 09:56 PM
220BR
I just put the xe-262-10 in my 383 this weekend. Broke the cam in this morning. Runs and sounds good.
USA Racing balanced the assembly for me and recommended the Crane springs over the Comp 986-16
Old 02-11-2004 | 11:28 AM
Formula78's Avatar
Have you ordered your cam yet? If not just order the kit, it's a good deal for all the parts it comes with. Just put a 'k' in front of your part number.
Formula78 is offline
Smitty
36
12-29-2007 06:07 PM
phughes69
7
12-15-2005 11:32 PM
JJONES
1
07-18-2005 03:52 PM
BAD-HABIT
7
04-05-2004 03:49 AM
