what spark plugs with blower
Numbers being higher or lower depends on the plug manufacturer... Ac plugs and Champion... The higher the number... the hotter the plug.... NGK... just the opposite. Smaller number is hotter plug.
I run anywhere from 10 to 15 lbs of boost, depending which top pulley I run, and use an NGK #6061.
That series of plugs has a huge ground electrode and are designed to be used w/blowers.
The only problem that you may encounter with this particular series is that they use a 13/16th plug wrench, not the small 5/8th's that most use. I turned the outer dia. of the large wrench down and it just fits in the head to put the plug in.
In my opinion NGK is the only plug to use in this application.
